My 05 GT Daily Driver / Resurrection Thread
sscobra
I'd been looking for an 05-09 for a daily for some time now. I finally found one back in May. I've slowly making progress. The goal is to have a clean and functional daily driver.
It's an 05 GT, auto, one owner, very early build, 10/04. It has leather, IUP, Shaker 1000, side airbags and the nifty roll the windows down with the keyfob feature.
And so it begins......
The night I picked it up
sscobra
First item, find the water leak!
Started with the usual suspects...
Cowl drain plugs, these are fine, right???!!!lol
sscobra
While we're in the cowl area might as well check out the cabin filter...
Seems legit!!!
sscobra
Next I moved onto the side window moldings, these are prone to leak as well. I couldn't tell you why.......:omfg:
I replaced both sides.
sscobra
Did a little clean up work.
Found the spare key behind the shaker 1000 trunk box and under the amp rack. No clue how that would of even gotten there.
sscobra
Went to install the Kenwood DVD player and had to remove some an old garmin and it's awesome wiring. :whymewhyme:
Also, swapped the center stack with an 08 model.
sscobra
The paint on the driver's side was pretty faded. Busted out the polisher. It'll do until it gets a repaint. The hood had tons of rock chips. I was able to source a very low mile black hood for a decent price. Problem solved!!
sscobra
BMR springs, KYB struts, bellows and bump stops, GT500 strut mounts!
sscobra
Lowered, stock wheels
sscobra
2015 Foundry 20" wheels, with new FRPP McGard lug nut kit.
jlmotox
Looking good!!!
What's the roll the windows down with the FOB? Factory?
sscobra
Thank you.
Yes, it's factory for real early 05 cars. Supposedly, there was a glitch early on and cell phones would cause the windows to roll down. So Ford decided to disable the feature going forward.
Bingo
Because street car
Phila, PA
Since when did `05s have side airbags?
Car is looking good. :thumb:
sscobra
Thanks. That's what I originally thought too. Apparently, it was an option in 05, and I believe mad standard on the 07+ cars.
