Floor pan distortion
rwleonard
Virginia
I have recently run across information suggesting that the s197 floor pan is at risk of distortion/buckling where the rear leg of the k member anchors. The info came from a pretty reputable source, but I can't find much of anything about it anywhere else. Anyone here have anything on it?
Norm Peterson
corner barstool sitter
RIP - You will be missed
It's true. If you use that area as a jacking point, the floorpan can and will distort, and you may notice that this has happened when you push on the floor with your foot while getting out of the car. You'll get a 'something just popped through' kind of sound that's similar to what you hear when you buckle a can.
The good news is that a little "persuasion" with a medium-weight hammer and a block of wood can restore the floorpan shape well enough to eliminate the noise.
rwleonard
Virginia
Thanks Norm. Have you ever heard of it being caused by hard braking on road courses with sticky tires, or just by mis-placed jacking?
Norm Peterson
Misplaced jacking is the only one I know of for sure. But it might be hard to discount something like the hitting of a hard bump while braking hard as a possible cause.
Fabman
Children Of The Corn
Pleasanton, Ca.
Both torque boxes that the k member bolts to on mine are bent but it doesn't transfer to the floor inside. There is some gap between the floor and those boxes. I have been looking for a way to pull that out so I can re enforce the area but haven't come up with a good method other than taking it to a frame shop. I'm open to ideas if anyone has done this before.
Vorshlag-Fair
Official Site Vendor
Official Vendor
Dallas, TX
Never heard of those areas bending or cracking without some kind of "jacking error" like Norm stated.
Fabman
Pleasanton, Ca.
I have a 4 post lift in my shop so it has never ever been lifted from that area on my watch. Regardless, they are both bent and short of chaining it to the ground and lifting the car to pull them out or taking it to a body shop I am not sure how to handle this. The car has a BMR K member so I don't think it has quite the support in that area that a stock one does.
RocketcarX
95% of my weight is fuel
Colorado
Will you post pics of the area you're talking about, plz sir
travelers
Eastern Pa
I'm glad I got the Steeda jacking rails on the car now. Yes it adds a few lbs. to the car, but I can live with that.
kazman59
King of Kazmania
Kazmania
I'm really starting to think of investing in those things. And I'm not otherwise much of a Steeda fan.
I installed 'em...
RocketcarX
Colorado
On my car those 3 inch diameter round holes just behind the K-member mounts are no longer round. Instead they are sort of distorted and bowed, are you seeing any of that?
Fabman
Pleasanton, Ca.
Mine aren't actually distorted per se, but since the plain of the hole is no longer flat it does give the appearance of them being oval shaped from certain angles.
Gab
Bullitthead
There's other brands for jacking rails, aren't there? Stifflers, maybe?
