Got the constant break light problem sorted out..it was a bad switch on the brake pedal. While messing with the fuse box in the SJB ( fuse #2 had to be temp pulled out)... I noticed the footwell area, like where a passengers toes would be..was very slightly, and I mean slightly...damp in 2 x spots.
I went through it all and couldn't find a damned thing. Have not used the car for 2+ weeks lately...and a LOT of rain. Yesterday, the entire inside of the windshield was damp with condensation. Cleaned that up..then noticed soaking wet napkins on the floor on passenger side. The passenger side floor was soaking wet..and then some. I had GT floor mats (rubber backed) on both driver + pass sides. Pass side floor mat was also soaked through. Water was collecting at the bottom right corner of the floor... WTF? Its all down the right side, starting at front end of sjb.....and all the way back along the edge.
Ok, what's the trick here ? Where the hell is the water getting in ? It's not coming through where the power cable from eng bay comes in....to the sjb box. The entire width, way up, is bone dry. Without tearing up the oem carpet on pass side, I can't fine it. That insualtion beneath the oem carpet on pass side is also soaked.
This is on my 2010 GT automatic.
I got all the water out with my 4 gal shop vac, then had the heat cranked to max for a while, but I have not solved the root cause. The drains on the outside, at base of windshield are good. It's not only baffling, it's really pissing me off now. And yes, the windows were up, and rubber door seals are in good shape.
