shikwann
Ive found a deal on this set up (saleen 35MM), does anyone know how well this would work together with the Ford Racing rear anti-sway bar?
Thanks a lot Sam! I really appreciate your advise. For autocross, what adjustments have you made to the front and rear sway bars? I might be in the market for anit-sway bars in the near future, I'll send you a message when I'm ready.It'll work. But the Saleen front bar is not adjustable where the other 35mm bars all pretty much are (well, not Roush either).
You'll get a decently balanced, but HEAVY set of bars (they are also both solid) where you could save about 20+ pounds and get 3 way adjustable bars @ both ends if you were to run bars like the ones I have/make which are hollow as well as both adjustable. Basically it's like getting 3 different front and 3 different rear bars in one set (since you can change the setting on each individually).
Again, the basic setup isn't bad--if you are getting it really cheap to make the bang for the buck better, but you can do better IMHO, even if it's not with my bars but say Eibach or Steeda (at least those both have adjustable/hollow fronts like mine, but solid non-adjustable rears).
