Tein S techs..
AJ
US Muscle, AUS Hustle....
Anyone running these? I have a eibach prokit but want to go lower and the s tech's seem reasonably priced. thoughts?
I either get this thing low low or I am buying a c6 lol
5.0Shocker
Resident Bomb Tech
Guam, Island life bruh
I have some in the basement, I will be installing them soon. The spring rate is softer than my FRPP springs, hopefully it's a softer ride. SHould be better for straight line too.
big4ever76
Montreal,Qc
do the tein S.Tech need a re-aligment and CC plates for the front? and a adjustable panhard in the back?
matt texass
I want to run some. Lowest available without coilovers I believe.
5.0Shocker
Resident Bomb Tech
I am going to run the J&M adj panhard bar and Camber plates with mine. The FRPP springs did ok w/ out; but I think the S-Techs should at least get camber bolts.
AJ
I will be running a CHE adj panhard. I'm just curious if anyone has used these springs.
rford426
Resident 5.0 H8R
Live Oak,Tx and Tulsa,OK
I have them running camber bolts and adj panhard need struts and shocks but the stance is SEX
AJ
O_O thats some unprotected sex right there
Kankakee
I dunno.
Hampton, VA
They sit lower in the rear then sportlines, but sportlines lower the front more.
I'm going to coilovers soon. The real "Get Low".
Black_GT
SIIXVII
Los Angeles, CA
I am running the S tech's also. They are a progressive spring which is nice. The ride sits pretty damn low. Handling is improved. I only have camber bolts and an adj. panhard rod in regards to alignment.
big4ever76
Montreal,Qc
what kind of strut/shock did you guys used?
where the adjust the rear? at the alignement shop or you do it yourself?
Thanks
o2sys
Bump...anyone else running them? I wanna know how well they ride. They seem to have soft spring rates (173/173) which is what I'm looking for.
