No RTV. They bolt directly to the cylinder heads. Might want to run a flat file over them to make sure there are no high spots.
Interesting...so no need to prime the tensioners with a garden sprayer...
I always get confused at this point. Does this mean that the engine is now timed correctly? Will you have to degree the cams still? It always seems like everyone throws the cams in, puts on the chains and voila, it's all good.
Maybe I just refuse to believe that something so important could be so simple.
Just curious, what oil do you plan on running in it? 10w40?
The oil I have chosen to prelube/break in this engine is Valvoline VR1 10W-30 Racing Oil - non synthetic. This oil has a high level of zinc/phosphorus to reduce initial break in wear.
