Question about stock stereo
Skudra
I have an 05 GT with stock stereo...not even the shaker system. My question is: is it wise to use the stock stereo with an amp and sub set-up? I have a Kenwood 1000watt amp and some 10 inch subs that I had from a previous car and Im wanting to put in this car. Do I need to get an aftermarket deck or will the stock one be OK?
Thanks
MikeVistaBlue06
Inventor: Asshole Points
Richardson TX
Thanks
You will probably have to get a line voltage to RCA jack output converter to make it work, and that method can transfer a lot of noise into the system. Sort of like using those old power boosters in the late 70s early 80s.
I would recommend a good front end unit that has RCA outputs so you can send a low voltage signal to the amps and then let them amplify that. That will reduce noise quite a bit.
Hope this helps.
Mike
