tagappliedfor
i installed these sportlines, everybody kept saying i needed to get a camber kit but i found out if you rotate the strut caps 180-degrees so the arrow is facing the opposite way it will offset the strut just enough to get the camber in factory specs. i was wondering if this would wear the tiny ballbearings in the strut top out, but i actually did this a year and a half ago (December 2009) and i've put 16,000 miles of pretty hard driving on it since then... my tires have worn evenly no problems whatsover. you can tell in the post how the strut rod is closer to the fender than what it normally should be
