RocketcarX
95% of my weight is fuel
If it is a fresh rebuild (new clutches) it doesn't matter what fluid you use, it will need at least 4oz of additive. Most times this is true of a fluid change as well.I was wondering about that. Wonder why Ford would leave out those additives when virtually every other 75w-140 gear oil has them? Would there be any adverse events if the Ford modifier is added to the RP gear oil?
