RocketcarX
95% of my weight is fuel
Rear lower control arms, new, installed and removed in the same day. BMR
Rear adjustable upper control arm, new, never installed. SR Performance
Panhard bar, used in great condition, BMR
$230 shipped for the package, will consider selling separately if the price is right
K&N "no-tune" air intake, used, in useable condition, rough appearance. I riveted the band to the intake tube because it would pop off while driving, problem solved and you can't see the rivets when the intake is installed
$100 shipped
SR Performance billet short throw shifter, in great condition, used for about 15K miles, some surface scratches you will never see when the shifter is installed. Included a factory rubber insulation boot that will fit over the shifter like factory as well as the Ford shifter arm, these are unique to the 05-09 GT and very hard to find. This one broke, I tapped it and it now uses a bolt instead of a stud, much stronger. Hardware included.
$150 shipped
SCT X3 programmer, unlocked, 1 use remaining, whoever uses this programmer next will be the last user or it will have to be sent to SCT for another 5 unlocks/uses.
It has the preprogrammed SCT tunes as well a few Lund tunes (VIN locked I'm sure)
It worked flawlessly on my brother's 07 GT automatic. The SCT tunes really woke the car up. You can change gear ratios, tire sizes, trans sift points, add or remove timing and fuel, change to an 87 octane tune as well as the 91+ tunes, lots of user selectable options. Will also upload custom tunes from any tuner you like. Has a piece missing that guards the plug, does not affect the programmer's use at all.
$150 shipped
All parts are located in Brenham, Texas
