07 Mustang GT SIGRTN
Fracke
Hello All, I have a problem with my 07 Mustang GT.
I have the DTC code P0345. I try all in the forums, change a PA Alternator, new VCT Solenoids, new CMP sensors, melling Pump, etc etc... And same result... at engine warm temp my engine run rough.
I follow the pinpoint test for p0345 and all ok but DR16
DR16 CHECK FOR A SHORT IN THE HARNESS BETWEEN THE PCM AND THE CMP2 SENSOR[/B]
Measure the resistance between:
SIGRTN - Negative terminal
Are the resistances greater than 10K ohms?
NO. REPAIR the short circuit. CLEAR the DTCs.
REPEAT the self-test.
test the harness and no problem but i have a doubt about PCM, I disconnect the PCM from the harness
the pin E58 is the SIGRTN
and the pin B47 B48 B49 and B50 are grounds
test with multimeter between E58 and whatever of these 4 pin (B47 B48...) and there are 0.5ohm
My question is, where should the 10k ohm resistance be? this means that there is a short inside PCM? or the 10kohm resistance is inside of the harness?
I hope you have understood what I want to ask. Thanks
xxdmxx
Test between CMP connector pin 1 & 2, CMP connector pin 2 & ground, and CMP connector pin 1 & ground with PCM connector disconnected. Meter should read 10K Ohms or higher or OL. You're testing to see if the two wires are shorted together. Did you do DR13 correctly and measure the resistance of the CMP sensor and not the harness?
