Hi all. That is the best time I have run so far. Car makes 470/440 with a Saleen. As far as suspension/traction I have the following: 4.10's, M/T 305/45/18 out back, 274/40/18 in front (I know, not helping), Centerforce dual friction clutch, Fidanza Al. flywheel, Al. driveshaft, Tokico D specs (full hard in front, full soft in back when racing), Steeda Ultralight lowering springs (I know, also not helping), Detroit Tru-Trac carrier, Moser Axels, BMR panhard, LCA, and UCA, along with LCA relocation brackets, sub frame connectors (welded in), with no weight reduction. My 60' is around 1.8ish. The clutch combo is like an on/off switch, so I don't ride the clutch at launch, and I don't powershift. Is this about the best I can expect, I mean I can't launch at over 3K without burning the tires off. I would think that even though I am not running an "optimum" drag set up (the car is more of a street race car to be honest), I still think I should be able to run better times. Please discuss.
