I REALLY like the aftermarket grilles for the 05-09 V6 mustangs but for us GT owners, the only aftermarket grille options are overlays and inserts. Nuts to that.
I wanted to see once and for all how a V6 grille would fit in a GT bumper and well frankly, it doesn't.
The mounting tabs are not the same on the bottom. The side mounting tabs are in the same spot but the grille is narrow and will not mount to them. The V6 grille is also a tiny bit shorter and when clipped into the upper retainers lifts off the bumper slightly so there are gaps all the way around. Here are the side gaps:
To get the V6 grille to fit right in a GT bumper, you would have to cut the mounting tab lip out of the GT bumper so the V6 grille could sit back in the well, cut up a V6 bumper to make pillar covers to close the side gaps, and figure out a way to secure the grille to the bumper since there would be no more tabs. Not worth it unfortunately even though the aftermarket V6 grilles are soo killer. Or just deal with the gaps and tape it in I guess.
