2005 Satin Silver GT 64k Miles
kevinatfms
EX-ford tech(6 years)
MD
2005 Mustang GT 4.6L 3650 5 Speed Transmission
64105 miles as of 10/28/14
I will note it up front, car was wrecked a few years back and was professionally repaired by the body shop at Lindsay Ford in Wheaton Maryland. 99% of the damage was body work while the only thing mechanical that had an issue was the exhaust pipe being bent. All fixed back to normal.
The car has been tracked most of its life so it has been through a lot. Its had heads, cams and full bolt ons for the most of its life and just recently gone back to a stock motor(has 127200 cams) and transmission. It has an exhaust rattle and a buzz from the trunk. Also will need the hood to be repaired where the hood pins were drilled(corroding). It has the dents and dings from being driven hard and has one small rust spot that has recently developed about the size of a quarter on the right side 3/4 panel. I have been quoted around $700 to fix all the dents and dings.
Mods:
Zex wet nitrous kit(jetted for 50hp)
SCT XCal3 w/ tunes by Woodbine Motorsports
FRPP 90mm CAI
Steeda Intake Tube
BBK 62mm Throttle Body
C&L Intake Manifold
Steeda Underdrive Pulleys
Comp Cams 127200 camshafts
Long Tube Headers(no name)
JBA Catted H-Pipe
Pypes Over Axle Pipes
Mac Mufflers
Barton Shifter
Shaftmasters Aluminum Driveshaft
4.10 gears
Auburn Pro Differential
Brembo Boss 14" Brakes
Steeda Brake Lines
18x9.5 Genuine GT500 wheels
275/40R18 BFGoodrich tires
FR500s knock off grille
Tokico "Blue" struts and shocks
FRPP K springs
FRPP Front sway bar
22mm rear bar w/ poly bushings
Whiteline LCA relocation brackets
Edelbrock UCA
BMR UCA mount
GT500 front lower control arms
BMR K Member
Corbeau Forza seats + brackets
Cooltech LLC harness mounts
Rear Seat Delete
Makes 330rwhp as it sits off the bottle. 414whp on the bottle.
Please PM me for phone number to call or text for more information/specific pictures. Asking 8k OBO. Title is free and clear. Car is located in Germantown MD zip code 20876. Will come with a few stock parts here or there.
kevinatfms
MD
More photos to come tomorrow when its light out. I will document all dents, scrapes and dings and full interior shots.
