2011 GT Radiator Fan Harness
filtercharger
Riverside CA
Asking for some help with the following issue:
My Radiator Fan died Friday night while I was at a drive-through, causing the temps to shoot all the way the Hot side of the gauge. I was able to park the car, let it cool off, and made it home. After troubleshooting pretty much all the fuses, relays, etc. I checked to make sure the Harness that attaches to the fan was securely connected, and it was, but I unplugged it to check it, and this is what I found (see image).
After talking to Adam from S.T. Motorsports, he mentioned that he had deal with the same issue regularly, and that the Fan was indeed shot, but that I should also replace the harness. My local dealers couldn't even find it in their system, no part number, nothing!
Any ideas, besides a wrecked car, on where I could buy this?
I already bought another fan, and everything works great, but the melted harness concerns me! thanks in advance!
barbaro
I have had to do this too as the exact same thing happened to me. In fact, I have the very same used harness sitting in my garage. The harness is very available and expensive through Ford. It will be north of $600 if memory serves me.
That little pig nose is not available anywhere. I looked and had people look for me. If you find one let me know. It will save you $$$.
did you check to see if that plug matches anything here:
http://s197forum.com/forum/showpost.php?p=450032&postcount=1
if it does, you could cut it out and splice in a new one.
9secCOBRA
Mine was burnt up looking, but still working fine, guess I need to fix this..
Steve@Tasca
Official Vendor
Hey guys, don't forget I'm here. :)
That connector is available as a repair pigtail P/N DU2Z-14S411-ABA $14.99 plus shipping from us. :thumb:
-Steve
Check the wiring at the fuse panel, it is likely burnt there as well. The 05+ fans are notorious for this. I ran larger 10 gauge wiring though out to fix it.
