2011 M6 GT won't go into any gear????
BPatterson
Clarksville, TN
Transmission grenaded itself internally. It's pretty much welded together. The tech couldn't even get it apart. They had to order a completely new transmission from the Dearborn assembly plant.
Seer
now that sucks.
BAKnBLK2010
Harley Davidson FLHTCI
Sandy Hook Kentucky
Sorry to hear that. So I guess they are covering it under warranty for you which is good to hear. Are they gonna replace the clutch assembly also?
DDTCM
Dan
Austin Tx
Hope you get it covered,that sucks.
Little off topic but is there some preventative maintanance to help these pressure plates bolts from backing out?
BPatterson
Clarksville, TN
They told me Ford recommended the new tranny, and I'm sure a new clutch as well. Will verify that tomorrow. Also, they were told to give me a loaner vehicle. There was no talk of any charges, so I'm assuming Ford is covering this. I didn't just want to come out and ask if it was being covered under warranty, for fear of them thinking I was guilty of something. I assumed like Seer said above, that if Ford wasn't going to pay for it, they would talk to me about pricing, what needed to be done, and if I wanted to move forward with them repairing it at my expense.
stevenstarke
yea don't ask directly if its being covered, if anything just say "This is all taken care of right?"
That's CRAZY that that happened. Did you push down at all on the reverse lockout when you shifted 1-2?
BPatterson
Clarksville, TN
Not that I'm aware of. Was just making a quick 1-2 shift, nothing out of the ordinary. The tranny had been whining in the first few gears for the past few weeks.
atistang
Ohio
fyi also, the clutch warranty is 12 months/12k miles. so it all comes down to when you bought the car since it has only 7,500 miles on it.
Are you sure about that? Bumper to bumper is 3 year 36k, powertrain is 5yr
mr. anderson
Moore, OK
yup, clutch is a wear item. just like your brake pads. so they may cover the master and slave cylinder but the clutch disc and pressure plate are wear items. just like they would cover your brake calipers, but not your brake pads, wear items have a shorter warranty.
see you beat me to the post Seer
Fast351
I can't drive 55
Twin Cities, Minnesota
On the other hand, if it's a component failure, not a component wearout, they should cover it. IE if the clutch explodes, pressure plate bolts back out, etc.
BPatterson
Clarksville, TN
Which my pressure plate, clutch disc, and flywheel are pretty much welded together, so I'll have to have a new one.
Trav4011
Hoosier Daddy?
Houma, LA
With all of the negative publicity surrounding the MT-82, I'm sure that Ford is going to cover this, no questions asked.
UnleashedBeast
Engine Lubrication Guru
Pensacola, Florida
Shifter bracket should solve a lot of this. Spirited driving sometimes "moves" the shifter out of place so the alignment is off. The stock bracket looks like someone who flunked basic mechanical engineering designed it.
I know, right!
Who was the genius at Ford who thought this would be sufficient?
