VET-KLR
I finally got all the pistons pulled from my factory shortblock and took pics. Just wondering if anyone can for sure say why they failed. This motor was ran 5K miles stock, 2K miles with Edelbrock E-force base kit w/ their canned tune, and 4-500 miles with 3" pulley(10psi?), Edelbrock CAI, UPR X-Pipe, Vortech BAP.
Can we get some technical information going on what kind of failure this might be. What kind of diagnosis can be made from these pics? Or would it take a hands on look and testing to determine failure? One thing to note is the damage was all on the outside facing side of the pistons. All other pistons show no damage I can see.
The #3 piston I think just took a piece of debris and broke the skirt. Also notice the crack on the side of first ring land. It showed 150PSI on cranking compression test.
This is #5 which read 90 PSI on cranking compression test. Cracked ring lands. It's about 1" wide section of ring land broke on each side.
This is #7 which read 95 PSI on cranking compression test. Cracked ring lands. It's about 1" wide section of ring land broke on each side.
Last but not least here are some different angles on #8 which rolled in at 0 PSI for good reason, and at least alerted me to there being an issue. Rough idle and smoking bad out the exhaust. Further checking under the hood and I found oil pushing past the air filter.
