46addict
13726548
And factory stock performance leaves me wanting more.
But losing an engine would be more expensive than losing track time, so point taken.
I haven't bought anything from MMR so I have no dog in the fight, but do you really think RTV can get past the rings, the oil pickup, and the oil filter and end up back in the head? Do you realize the texture of RTV once it dries, and how small of a gap there is between the cylinder and the piston ring?It sounds like they were properly sceptic though, if RTV started up top. Where else would it have been used if not for the timing cover? That’s a tough situation for anyone and any business, and your local dealer or even a lawn mower shop would give just as much of a raised eyebrow.
I can tell you i have used their 4v replacement keyed cam gears in a build and they were junk. Two of them split from installation before they would accept the recommended torque value of the cam bolt. The gears showed up with no special instructions and in a plain box.No I don’t, and I’m not arguing specifics; merely pointing out there is often more to the situation than portrayed by the one accusing.
Sent from my iPhone using Tapatalk Pro
MMR said you have to "fit" each gear with a dremel so they don't interfere with the cam. Meaning they aren't finished machined and require "fitment"...a cam gear. Name one other application this would be required from a engineered product for a specific application that.
They sent me the replacement gears for free, but the whole thing could have been avoid with a simple instruction sheet or one more step in the manufacturing process.
I did not install the cam gear improperly, they are not finish machined and sold without instructions of any kind. They broke while being torqued to a cam in a fixture. If you know about the 4v heads they are keyless, requiring a very specific tool set to set up the engine. These keyed gears are supposed to eliminate the need for that.Glad to hear they sent a replacement.
For your consideration, when I started this build, I found my block had been cracked from a mechanic having over-torqued some bolts during a TSB repair. Obviously upset, I childishly took to Facebook about it and was corrected by a friend who is quite respected in this industry, and he suggested I give them a chance first. Long story short, the dealership worked with me and took me at my word, funding half the price of a replacement block, even though that mechanic is no longer with the dealership. Now that I am thinking rationally, I realize they went above and beyond, and could have simply told me to go away, but the fact that they even covered half is truly awesome.
I highly recommend them partly for that reason and left them a 5 star review.
Someone else may have felt they should owe them the world, and obviously there are those that had they received a full replacement block, would still leave negative feedback on the Internet.
I don't want to be that guy.
The back side of the gear isn't machines to sit flush against the cam, I had to shave the gear basically. Mostly around the key.That keyed gear looks not bad - what the heck were they expecting you to grind on!?
