<----no tracking info
Hopefully Tom
Mine says 22nd for deliverydate via UPS
Put mine in tonight. A lot of thought went in to making this shifter really quiet and the shifts are extremely concise. Install took about 2 hours on jack stands. The quality of the individual parts is phenomenal. I thought the MGW in my Cobra was great, this things is light years ahead. I didn't get a chance to get on it hard because its pouring down rain here in S. Louisiana.
Still no email on mine....
here is an awesome link with a bunch of detail about the shifter....
http://www.svtperformance.com/forum...mgw-mt-82-shifter-preview-install-review.html
My understanding is that both the 2011 and 2012 V6 and GT use the MT82 manual transmission. If that's the case, then I see no reason why the shifter shouldn't work on the V6.Maybe a dumb question, but does the V6 version of the trans take this shifter too?
Got mine yesterday and installed it last night, its perfect george you nailed it!! what I love most is how the gear is where it should be while hard on the gas , my factory unit had a hard time finding 2nd under power shift conditions, now i get that great mechanical feedback and positive engagement of each gear. I wish I had ordered a ralley ball at the same time (dang).
tech notes: If you leave the linkage installed on the trans , and you are doing the whole install in the car , i feel that dropping the driveshaft would have saved me a bunch of time!! it would have been much easier to get to the bolts though it wasn't bad .
2. if you find your new dust boot doesnt fit or seal up just right rotate 180 degrees and reinstall, the hardest part of this whole thing for me was getting that boot over the housing , its a tight fit as the video explains, i put the dynamat down after the boot was installed and sealed the rubber edge , i also put the sound pad that mgw sends with the kit down first and then the factory sound pad on top of it, and it seemed to be quiter , i tried it both ways and i found this to work best for me!!!
this was a very well though out design and well worth the time waited ,I feel sorry for everyone who went the other routes b/c this shifter is the *shit* thanks again george
I never had any grinding issues, but finding gears under power was a bit of a problem. The mgw unit solved that for me!! as for the notchy problem, I assume you are refering to how you try to shift into a gear and it seems to go half way and the kinda click in. I would say its greatly reduced, every once in a while this happens but im sure its gonna go away with wear. I only have 2k on it and 400 miles on the new shifter so far, so ill keep updating as I go!
