2013-14 Mustang BOSS 302S / 302R 4" Brake duct kit
Rehagen Racing
Westland, MI
Now you can own the same brake duct system used on the 2013-14 Ford Racing Boss 302S and 302R Mustang.
-Includes 4" thermal brake ducting
-Carbon Fiber brake spindle ducts
-Plastic bumper insert ducts
-4 stainless hose clamps
-4 zip ties
This is perfect for Road Racers, and Track Day enthusiasts. (Requires removal of factory windshield washer bottle)
Lower brake temps to extend pad and rotor life, eliminate brake fade, and increase performance.
2013-14 Boss S Brake Duct Kit
Rehagen Racing
Westland, MI
It's completely different from the LS kit. The LS kit uses 3" as mentioned, but also uses a small front plate with only a 3" opening. The LS kit also does not have the carbon spindle plates.
Our kits are the same as what is used on the Boss S and Boss R race cars. First off it is 4" tubing which will flow significantly more air than the 3" tubing. It also has the carbon spindle plates, and a HUGE front snorkel that takes up the entire foglight opening on the 2013-14 front bumper.
Our kit does require you to remove the factory washer bottle, as there is no room to clear the front duct and 4" tubing.
We use these on all of our cars that see track use.
