one eyed willy
Pizzle fo shizzle
Not sure, I have no issues with 13 internals...but I'm using a oil-less turbo.
So do you think that I should just keep the '13 spring in the pump or swap in the 3v spring?
Subscribing...doing the same but need to know what spring is best. Wondering if the +10 oil PSI one-eyed Willy reports is a good or bad thing. Using 13 pump + TSS billet gears.
Good info and back from dead again. I'm about to pull my 13 pump and boundary gears off my new 3v build and go back with tss gears. I have been having low oil pressure issues with slightly wider tolerances.0018 to .0020 and 20w50 oil. 15 psi warm and about 35 @ 2000 rpm with 80 psi @ idle cold. Will keep al posted if gears end up being my issue
FRPP said that nobody they have heard of has ever replaced the relief spring with the GT version. I was under the impression the relief spring was for cold starts or high rpm operation before the oil was warm. Might be different for these pumps.
Edit/unrelated: I see ford racing sells a pump with billet gears for the 5.0 platform. That's pretty interesting.
