ford20
Those clearances are well within normal for a mod motor. I wouldn't be afraid to run 5w20, your turbo might need a little more viscosity though. 5w30 should also run just fine with those main and rod clearances.
As an update to this thread I did a csi on the pump prior to putting it in. The gears are exactly the same as a 3v pump. The pressure relief spring was different. It allows for a higher psi prior to opening the relief valve.
More on the pump differences here: http://www.s197forum.com/forum/showthread.php?t=106434&highlight=oil+pump
Those tolerances are looser then on the TSS gears. I don't know what factory tolerances are though.
