2014 GT driver window
Tommy Oliver
I’ve recently replaced the window regulator,motor, and switch on the driver side of my 2014 5.0 and the window is stuck down still. The window will go down no problem but when trying to go up it just clicks does anyone know what the deal is?
Iceman62
Bullitt 6005
NE
How are the window tracks/alignment - something's definitely not mating. Were the replacement parts new, or pulled fm donor car (salvage lot, 2nd hand part)?
Tommy Oliver
Everything was replaced with OEM new parts i plugged the motor up by its self and no matter what direction i hit the button on the switch up or down the gear in the motor spun the same way counter clockwise
07 Boss
Sin City
Reverse the polarity on the motor and see if it spins the other way. If it does then you have something wrong with the switch or the module.
