2015 Fuel Pump??
Discussion in '2015+ S550 Mustang 5.0L Tech' started by REDS197, Oct 8, 2014.
  1. REDS197
    REDS197 Member
    505
    Feb 3, 2010
    Denver
    Can anyone verify if the 5.0 fuel pump is the same as 11-14. I know the injectors and the fuel rail are. I would like to verify this so I know the factory pump limits.
  2. Steve@Tasca
    [email protected] Official Site Vendor
    1,291
    Sep 23, 2013
    Other than that it's a brand new for '15 part number I'm afraid I can't tell you anything else.
    -Steve
  3. BMR Tech
    BMR Tech Traction Vendor
    4,861
    Dec 15, 2009
    Tampa, FL
    The pump is a different part # and engineering number.
    Rumor also has it, that they are making more power without needing boosters.
    I can also tell you,from ripping these cars apart - the feed line on the 15 hats is larger now.
  4. JeremyH
    JeremyH 3V Fuel Guru
    20,517
    38
    Jan 10, 2009
    It appears the 2015 coyote pump/system can handle around 700rwhp on a turbo car so I do believe there have been changes. Supposively they can support 900rwhp+ with a 21volt bap as well... I cant confirm this stuff though.
  5. konablue11gt
    konablue11gt forum member
    1,322
    Jan 12, 2012
    Evansville IN
    can they be retrofitted into an 11-14?
  6. Mustang Mark
    Mustang Mark forum member
    476
    Oct 18, 2013
    PA
    Or even an 05-09 for that matter.
  7. JeremyH
    20,517
    38
    Jan 10, 2009
    Not sure, time will tell when someone digs into one.
    No, not easily anyway, its a different fuel system than 05-09gt and different than the gt500, its a mechanical returnless with a regulator on the hat, different fuel tank and hat design, pcm and pump controller are different as well not the same as an fpdm on 05-09.
  8. Mustang Mark
    476
    Oct 18, 2013
    PA
    Good to know, I haven't done any research, but I will need to soon considering I just bought a blower.
  9. REDS197
    REDS197 Member
    505
    Feb 3, 2010
    Denver
    2015 Fuel Hat. Looks almost identical.
    The line inside the fuel hat is the same. The outlet on top of the fuel hat is larger by 1/16th.
Share This Page
