2012Coyote
Fuggit.
So I just picked up this 2016 F150 as a daily driver, and to tow the mustang to the track, but decided I liked it too much to put that many miles on it, so I got a fusion too, and I'm going to build the truck into a modern Lightning.
It's a 2016 RC/SB 4x2 with the Coyote. It has 385hp stock, which is more than any year of Lightning from the factory, and it only weighs 3,950#.
Originally, I thought Whipple or Kenne Bell, but I fuckin love the turbos on my car. So I've decided on a single 88mm.
Here's the parts list:
Engine:
On3 88mm Ball Bearing
Hot side from CG Fabrication (T4 hot side kit made for Coyote swapped Fox bodies)
On3 4" Intercooler
On3 44mm Wastegate
On3 50mm BOV
On3 Turbo Blanket
On3 Turbo Filter
ID1000's (maybe 1300's)
MaxFlo BAP
4" single straight exhaust from turbo to in front of the right rear wheel
3.5" Cold Side Piping
Drivetrain:
Circle D 258mm Stage III Converter
Circle D Flex Plate
Ford 3.73's (maybe 3.55's) (has 3.31's in it stock)
Stock 9.75" E-Lock
Stock driveshaft
Suspension:
Belltech 3/5" drop
Calvert Racing Traction Bars
Wheels/Tires:
-KMC Slide 22x9.5 +15mm with Nitto 420S 285/40R22's
This complete list will cost less than $9k (not including tuning), but less than $40k for a 700+ rwhp hellcat killing pickem up, doesn't seem too bad.
Sent from my iPotato using Tapatalk
Engine:
On3 4" Intercooler
On3 44mm Wastegate
On3 50mm BOV
On3 Turbo Blanket
On3 Turbo Filter
MaxFlo BAP
Drivetrain:
Circle D Flex Plate
Stock 9.75" E-Lock
Stock driveshaft
Suspension:
Belltech 3/5" drop
Wheels/Tires:
