BlownAway05
still too slow
Looks like the 3V aluminator now comes in stock 9.8 compression, I'd like other's insight on what they feel would go better with the 2.3 whipple, the aluminator with 8.7 compression or the 9.8 compression?
You can only spin these whipples so fast, seems like you will need max out the blower rpms to really make some decent power (600wheel on pump?) with the 8.7 comp. But you get into very small pulleys and belt slip can be an issue.
Would the 9.8 comp with lower boost be the better choice, so as not having to max out the blower rpm?
I'm under the impression that running lower comp, more boost is better due to the fact that the overall cylinder temp will be lower because boost heat is controlled with the intercooler, where as compression heat cannot be reduced (except for unburnt fuel), making pump gas a more viable option?
Any input to help create a clearer understanding of what might be the better option would be greatly appreciated. The biggest concern with me, is that the 2.3 whipple might not have enough room to grow with the lower 8.7 compression.
