Some of the F-150 ECU's have Flex Fuel built in. Could that be used?
So what happens when u have a 1/2 tank of gas...and half a tank of E85 ? Do you end up with E40?
Does anyone know if it's possible or if there's a system being developed for us 3V guys to run flex fuel?
I'm going to run e85 in the near future but I would love the versatility of flex fuel.
Yeah the wideband front 02's is what allows the 11+ to do it.
Leaving a little 91 just makes the car a little richer/safer. E85 is 85% ethanol and 15% 80ish octane gasoline. When running a e85 tune if you get e80 or e70 the car runs richer from more gasoline, more ethanol would make it leaner. I wait till I'm under 1/8 tank, load the tune as I fill with e85 and go. It stumbles at idle for a little bit as the gasoline gets out of the line, then good to go.
Did you change any part of the fuel system or anything else to run e85 or is only a tune needed?
I run a return system and have two tunes.
