silver rhyno
Right now I'm running 4.10s with a 28x10.5 slick with a 5 speed the car cuts 1.70 60ft time...is changing to a 4.56 gear going to help me?and if so how much? If I do the swap I will install a true trac while I'm there....
1.73 60ft 8.07@86mph 12.64@107 N/A
7.79 @ 86.something IIRC best.BTW roji what does your run run in the 1/8????
I run 4:56s with 28inch tire and it works out good. Goes through the traps at 6200 to 6300rpm.
How are they for street driving?
It's a stick car. I go through in 4th but maybe my tach is off a little. The 109 was at 6000rpm but it usually trap higher, at 113 so it's 6200 most of the time.my shift light and tach must be way off. i trap 114 with a 26" tall tire and the shift light comes on just as i'm passing thru the traps and it's set at 6500rpm. i'm not sure how you can get that rpm with a 28" tall tire and only run 109 mph.
even using the rpm calculator, i come up with 5964 for your set up. and if you get any tire growth, that will reduce the rpm even more than that. when i use the calculator on mine, the mph and rpm works out to a 27" tall tire even though it's a 26". I assume the tire grows some on the top end making the number slightly skewed.
are you running an auto with a loose converter?
