I am noticing now that I'm looking at forged short block options that many boosted builds are staying 11:1 CR even seen some running 11.5:1 boosted instead of the old trend of running 8.5 - 9.5:1 or so on boosted applications.
I'm in the planning stage of my boosted coyote build so I'm deciding on the CR.
I am curious if any durability increase would be seen if I were to tick the CR back to 10.5:1 I don't want to run under 10:1 due to i want a more instant throttle response. So is the accepted norm of boosted compression on the new engine higher for a reason if so what makes it more acceptable than it was on 3 valves?
Every tuner i knew previously freaked out at the thought of running higher compression with boost especially on 93 pump street/strip now it's accepted by builders and tuners?
Sent from my DROID4 using Tapatalk 2
