KIMMER
Admin
- Joined
- Apr 9, 2007
- Posts
- 5,210
- Reaction score
- 22
Well, got the auto swap done on my car but have an issue with a noise coming from the trans area and some strange symptoms. At first we thought it was the converter, so I got a circle D 3000 stall multi-disc for it and I still have the same issues. Trans makes a lot of racket around 40mph when you start to get any kind of load on it, like going up a hill. Also, the trans is making the converter stall way higher than it is suppose to be and feels like it struggles to ever allow the converter to lock (this happens to both converters). On the dyno, it seemed like the trans or converter was slipping, but it has to be the trans due to me swapping out the converter. The only thing we did is add a hardened input shaft and I had billet servos installed at a trans shop. Anyone had these issues before or know of someone who did and what the cause was? Could the anchor nut cause this if it had fell into the trans when the shop did the servos? What about the valve body? Just trying to figure out my next step to this cursed car that is about to get traded in if I don't get it fixed soon!
Here is a vid clip of the noise, you'll have to crank your speakers. It's the rattling sound.
http://s305.photobucket.com/albums/...ew¤t=photobucket-6781-1309645519601.mp4
Here is the dyno sheet and you can clearly see something isn't right when you look at the torque curve.
