05stroker
Never enough power guy!
I am saying that I purchased a flexplate from a 4.6 (Ford Van but there are many that interchange) engine that uses a 4R75E. It has 6 bolts and an 11.5 inch torque converter bolt pattern that is used with the 6r80. The starter tooth count matches the stock (to our cars) starter. It is bolted up in my car but I have not started it yet.
I did not search for a flexplate out of 5r55 car because they are different. They have some sort of a spacer to match the 5r converter.
I am no expert. I am just asking why you think it will not work.
I just know all flexplates are not the same off set. I was asking the question so I could order one for myself. Did you measure the distance from the convertor to the flexplate before bolting it up by chance?
Im assuming you didn't notice anything odd furring the install.
Im just trying to make sure what I order will work.
