6R80 transbrake tech discussion
tvanlant
Can someone please help with the 2 relay set up? I am getting the car tuned next week and would love to have this set up by then, I just dont know where to start, and sorry I am so stupid when it comes to wiring..
Replied to your PM. I will try to make a new how-to thread tonight
billy mack
SO happy for this, being a bracket racer it is very hard to compete when you foot brake..
nonliberal
So has anyone heard of any tranny issues or failures caused by this mod yet? It would be very helpful but I'm not ready to place the tranny just yet..
kdanner
Austin
I've got something new cooking, a revised circuit/calibration, it uses one less clutch. Good track test on an NA car last weekend, and looks good on a blown car in driveway testing yesterday. Track testing the blown car on Friday hopefully.
onebadgsx
Houston, TX
anxious to see the outcome. i have yet to wire one up. im am ready though
Justinjor
JUIC3D
+1 !
I'm waiting for circle D to figure out the new converters for my late 2014 so I have a little time before I'll need a tbrake
kdanner
Austin
No test of the new one tonight, fatal on-track accident, very bad situation.
kdanner
Austin
Getting this back on track. New transbrake circuit. When activated, this one has only the fwd, l/r, and int clutches applied. No more direct clutch like the previous. However, it absolutely requires proper PCM calibration. Lund Racing is aware of what is needed for that. Tested on a TVS car with 2C converter, with no 2 step connected the car is at the limit of the converter just above 4000 RPM and makes no attempt to move whatsoever.
onebadgsx
Houston, TX
Awesome. Thanks for all your work danner
D98GT
STREETCAR
Liberty TX
I might talk to Daniel at TSS to see if he's played with this as of yet. Do you happen to know Kris?
Justinjor
JUIC3D
Are the PCM calibration changes going to be made public knowledge? Anything extra required besides raising stall speed?
kdanner
Austin
Not giving calibration info out to others, I only wanted to work with someone both trustworthy and capable. I suspect some others will figure this out after seeing the circuit if they just put in some effort. This will not even function as a brake at all without the correct calibration.
CPRsm
Why use this one? Does it release faster than your other one?
kdanner
Austin
No way to time it really but possibly. Once I figured out this calibration deal I just wanted it use it to simplify the hydraulics. It was never a matter of really needing the direct before, but I needed to borrow the circuit, which caused it to apply.
Justinjor
JUIC3D
Fair enough. Thank you for the effort with the transbrake stuff. The DIY crowd (like myself) appreciates the outside-the-box thinking very much. :thumb:
DVEST8R
Successfully did the 2 relay version on my friends coyote along with a 2 step.....its a very dirty set up. I must have an auto coyote now. Thanks for the DIY support Danner
TungstenGT
Going to be wiring this up along with a msd two step on my nitrous car. Any tips on where everyone is putting the relays/ wiring?
