Wickedxrebel
Hello all, I have s V6 vert that has blower motor problems. I’ve isolated the pink blower motor wire out of the harness to make sure connection is clean, and I’ve swapped both the blower motor, resistor and relay all known working from my GT. I also removed the cabin filter. It blows but just not very strong at all, nothing like my GT on high. I know the dash’s switches are probably next, but…
When I have car running, The connector that goes to the blower (pink wire side) has 14.3 volts when set on high. But it also has 14.3 volts when set on low. Isn’t the resistor supposed to make the supply voltage lower for the lower settings? Maybe I need to put the parts back in my GT and test that theory.
Also what’s the best or easiest way to Hotwire the blower switch to run on high through a small aux switch? Also, where does the red wire (next to the pink) that plugs into the blower motor go to?
thanks
D
thanks
D
