Removal and Installation
Lower the glove compartment.
Disconnect the temperature blend door actuator electrical connector.
Remove the 2 temperature blend door actuator screws.
Remove the temperature blend door actuator.
To install, reverse the removal procedure.
NOTE: The purpose of the module actuator position calibration is to allow the HVAC module to reinitialize and calibrate the actuator stop. points. To carry out calibration, carry out the following steps. Remove Smart Junction Box (SJB) fuse 10 and SJB fuse 12 for at least one minute.
NOTE: When the ignition switch is switched to the ON position, the HVAC module will initialize and calibrate the actuators. Calibration of the actuators will take approximately 30 seconds. NOTE: If the actuator fails to calibrate correctly (mode door does not work correctly), inspect the plenum chamber for foreign objects or debris. Reinstall SJB fuse 10 and SJB fuse 12 . Turn the ignition switch to the on position and wait 30 seconds before verifying correct operation.
