My previous problem was resolved after I found 2 cracks in the stock intake and replaced it. I had air getting in under vacuum and it was skewing the fuel trims. So, after replacing the intake, and also my primary O2's, I'm now having an issue where my cruising air fuel ratio is hovering around 16.5. I have already disconnected the battery and reloaded my tune hoping that might help. If I disconnect the battery, it takes a while for the air fuel ratio to get up to 16. It will be mostly normal for a few miles, then gradually I will see more 15's then it will switch to 16's. At WOT it's a rock solid 13.4. Any ideas appreciated.
