one eyed willy
Pizzle fo shizzle
I've had this happen before, ended up being a exhaust leak.upstream of the wideband would suck in air as the exhaust passed by.
How long since you changed the sensor, 702?
I will probably pop in a fresh sensor. Maybe a year is a decent lifespan for an aftermarket WB? The guy at zeitronix said that when they go bad, they really flop out and will get stuck or be obviously wrong. My plugs are a lot whiter on the passenger side - I wish I had put my wideband there. I will put bungs in both sides if I put long tube headers on next year.
I'm glad everyone's innovates worked well. Mine seemed accurate, I just hated never knowing if it was calibrated and I much prefer the little box I stuck behind the dash and stand alone gauge I've got going now.
Popped off the filter, MAF wires appear clean, no excess oil anywhere in the intake tract. I'll spray the sensor with cleaner and change the fuel filter before I datalog. Hopefully it stops raining this weekend.
LOL I sold my piece of shit innovate to a guy with a carbed VW bug. The McDonald's of widebands! Have fun rolling around on the ground pulling the sensor for free air calibrations!
http://www.zeitronix.com/
edit: that MTX-L looks nicer than the LM-2 I got rid of. Still have to do the free air cal. Nope.
Any chance it's the O2 sensor?
They do go out from time to time. Have you done a calibration procedure lately? How about cleaning the maf? Basically the maf isn't reporting the correct airflow and that can be caused by a dirty maf. Seeing 14.7 in closed loop means that the o2 sensors are still within the range to trim the a/f. Have you checked the short and long term trims lately?
Edit: Is your air filter oiled? If so it's quite possible to over oil and have some of the oil get on the maf. That situation could cause exactly what you are seeing.
What is Zeitronix...? Maybe you should get a reputable AFR gauge like a Innovate Motorsports. Has a lot better resolution also.
http://www.innovatemotorsports.com/products/MTXL.php
You can download the data along with the PCM data all in one shot and graph it all together.
I was under the impression the Innovate was the wide bands of all wide bands. Super accurate and tuners love them.
Was I mis-guided?
I have the LC-1 wide band too and the original sensor did go out a couple years ago on me. The LED light would not stop flashing even after recalibrating it. I replaced it and it's been reading fine ever since.
The best consumer wideband per Lito is the AFX wideband...that is what he recommends.
DiMora you're killing me here... I just bought two Innovates!!! sigh
Gerald - I jinxed myself. Mine failed tonight. I'm hoping it just needs re-calibrated.
Uuuugh.
How does it fail? And which model do you have? The MTX-L?
You are worrying me now... I am depending on these AFRs gauges to warn me about running too rich while I break-in the motor. I got one for each bank.
Not sure what to do now...
Really? Nothing has happened yet. You bought LC-1 correct?
Believe everything will be ok and save the panic. If something happens then the heavy sigh. Until then just smile.
No, I bought the MTX-L.
I haven't even powered them yet...still waiting on my short block.
