Air Line Fitting Question - Jeremy?
Scott
King City, Ontario, Canada
Getting down to the short strokes on swamping my differential for the shortened one I have been building.
When I disconnect the air lines from the bags should I make a new clean cut on the air lines, or is this not necessary? Not a problem if you recommend a clean cut, just a cramped space to work in, even if I pull the lines back into the trunk.
Wes06
It's usually recommended to do a clean end on fittings, but removing my tank and reinstalling I just kept the same end. Just don't butcher it and keep an eye for leaks
Scott
Thanks Wes, I guess I knew that was the recommended approach but was just procrastinating. Will see if there is enough slack to pull the line down from underneath otherwise I will need to get someone younger and smaller than me to jump in the trunk!
