AirLift/Rotiform Install Write Up with Lots of Pictures
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Is it done yet?
Wes06
Get some Windex or just soap+ water in a spray bottle and check the fittings all around. I can go a week not touching anything and my tank will only lose 2 to 3 psi. Bags are about the same
HellsBells
620/677
SoCal
Upper shock bolt? What about the airbag? I am a little concerned about the lower bolt that hooks the bag to the axle since you don't thread much of it and it appears loose. I guess it's normal though.
Sorry for getting back to you so late. I got the bottom nut/plate to be really tight. Just keep turning the bag as much as you can. So far no problems with my bag top mounts. My driver's side top shock mount was almost 100% unthreaded. I noticed a clinking noise over bumps and the washer sandwiched between shock rod and the OEM metal washer (the one that presses against the rubber bushing) was free to bounce up and down.
HellsBells
620/677
SoCal
Like Wes says, soapy water is great to find leaks on bags/fittings. Be liberal with it. It can also be leaking from the AutoPilot V2 controller box connection.
Might need to unthread the airline to the bag and put more thread sealant on it.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Love the air and the car, I would have just wanted the wheels to "tuck" inside the fenderwells when dropped if it were mine.
Good job on install!:clap:
Wes06
Check out mine Darren. My front wheels do just tuck in. I'll trim the rear bump stops to tuck the rear slightly
GallopingFord
I'm Cam - Mr. Indecisive
Northern Virginia
Thanks! The fronts will tuck more when I adjust the camber. I'm aiming for 2* in the front. The rear offset is pretty low so they stick out but considering its 315 on a 12" wheel it is not bad. I have a 1/8" spacer on right now I may remove. I took it out on one side and the clearance is pretty good from the sway bar.
Here are better pictures.
Car still needs to be put back together but for the most part the install is done. I'm in love!
TRC51
Mmmm fuck all that lol
That's too much work for my liking
LOL... I was literally saying to myself... that was such a good/detailed write-up that it completely convinced me that I want nothing to do with it. LOL Love the airlift.... but I am paying to have it installed.... if I can afford it.
