Any Experience w/Turbonetics ...
drive_55_not
Turbos ..
I am looking at the 7875 .96ar or 7575 Billet 1.15ar. Looking/needing to make 750rwhp.
I've got a big bore stock stroke, FRPP CNC 3v headed motor that I hope to have back together for Xmas.
Goals for the car are [which is a heavy ass 4200lbs land yacht] is low 6's @120 on the 1/8th rowing the gears with a T56 and 3.08 gears. I'll be using as much nawz as needed to get there.
I'm leaning toward the billet T7575 and from what I've been reading it is comparable to the PT7675 CEA but I'm not sure how that 1.15ar is going fare on a little Mod Motor.
I know the Percision PT7675 is a proven unit and there is a lot more info on those setups but I can get either of those Turbonetics considerably cheaper. Getting a modified on3 hot side piping and will be fabbing an A2W IC setup.
Currently with my TVS setup the T56 needs to be shifted at 7000, I'm not sure how far out the stock 3v intake can hold power from what I can tell it's dying past 6500. I know a bigger A/R can help some but isn't a fix-all.
May also look at the Comp 7879 as those are decently priced.
Thank for any help and have a Happy Turkey Day ..
