I think this conversation has gone a little astray . . .
I don't think that running 255s in a less grippy compound than the rear is going to turn the car into a whirling dervish deathmobile but, for those of use that like to push our cars in the corners, the idea of using huge near-R comp tires in the back with a less sticky 'street' compound tire of a much narrower width means that the handling characteristics will be less than ideal (i.e. tendency to understeer) unless some pretty substantial suspension modifications are done (and even then, the proposed combination is not ideal by any stretch).
Ideally, you don't mix and match brands/models of tires on a car that you want to go around corners with, although this might not be a concern for the OP.
