Anyone have a DIY on belt removal?
Black Tooth Grin
Earth
Take a 1/2" drive ratchet or breaker bar, stick it in the hole on the belt tensioner at the idler, push down. Release tension on the belt, slide it off the alternator. Relax tension on the tensioner, remove the ratchet, slide the belt off.
Doesn't even take long enough to finish half a beer.
08VistablueGT
Booyakasha!
Reston, VA
Wonderful, thanks a lot!
blackgtrag
use a breaker bar. its probably too hard with a ratchet but yes good intructions.
oh just pull off the alternator nothing else to aid in rerouting
08VistablueGT
Booyakasha!
Reston, VA
Awesome. I will be recieving everything on Tuesday! WAHHOOO!
Do you guys know if there are any special splines/tools needed to remove any factory pullies?
