Anyone notice Trac Control Problems when rear tires taller than front?
Mishri
Great Falls, MT
ABS fault? anti-lock brake system fault? i didn't get that message when i dyno'd my 2007, and i was the one in the car. I just turned off traction control and got no warning lights. I dont' know why you'd get a brake fault message anyway, traction i could easily see though.
J.Kidd
Suffield, CT
For reference, when I press the button once, it says "Traction Control Disabled." If I press twice with the brake pressed, I get "Sport Mode Enabled." If I hold for 6-7 seconds with the brake pressed, I get "AdvanceTrac Disabled,"
Just checked it. This is what I get:
1) I press the button once, it says "Traction Control Disabled."
2) If I press twice with the brake pressed, I get "AdvanceTrac Sport Mode".
3) If I hold for 6-7 seconds with the brake pressed, I get "AdvanceTrac Disabled"
Grimace427
Hellhound
Northern VA
One click: Traction Control disabled
One click again: Advance Trac enabled
Two clicks with brake depressed: Advanced Trac Sport Mode
Press and hold with brake depressed: Advanced Trac disabled
