BigSkyGT
Not your daddy.
So now what? I can't unlock the car because the battery is dead. For some reason my key won't manually unlock my door. How the heck am I going to get power to the car to use my power locks?
You should be able to manually unlock with the key, regardless of having a dead battery.. If the lock isn't frozen and able to turn, but still not open ?
Your tumbler assembly might be the problem.. Just a guess on my part
This is correct. The key lock is manual and does not rely on battery power. I think clockwise is lock and counterclockwise is unlock. The connecting rod to the lock could also be broke or disconnected somehow.
So how to get in? It might be possible to reach up to the hood release cable and pull it enough to get it to release. If you can't reach, try using a coat hanger or something to get a hold of the cable and give it a tug.
can you climb in passenger side to pop the hood and open driver door? then you can get new battery, and get it open to tear apart to figure out whats wrong
was just about to ask about the trunk but your convertible
does the key not work on either door?
Wes ! only the driver's side can be unlocked with a key.. There is no door key slot on the passenger side..
