I'm trying to plan a build on my 09 GT/CS. Option one is to go with a supercharger and leave the internals stock. This car will likely never see more than 4 or 5 passes down the quarter mile. Most of the time it is a weekend/cruise-in warrior with the occasional run through the gears on a straight back road in the middle of nowhere. My car is a manual 5-speed.
I know the rods and then pistons are the week link on the stock internals. So I am considering three ways to approach this.
1) Vortech V3 Si-Trim - I'm actually not a fan of centri super chargers because the plumbing is cluttered looking and they are the noisiest SC at idle. I don't mind superchargers that whistle/whine under WOT, but I can't stand a loud whistle (or worse the can of rattling marbles sound) at idle. I prefer it not to be evident that the car is blown at idle. The upside on the Vortech is price and I have read the centri superchargers are not as hard as a roots type on stock internals (not sure if that's true). I think I could get this done for less than $5K.
2) Roush - Not sure which way to go here M90 is a bit of a lightweight, but is cheap and supposedly safe. The next step up (2300 TVS?) is upgradeable but starts at something like 475 hp. I like the numbers quoted with this, the Roush is a relatively clean look under the hood and seems to be relatively quiet at idle. Probably more expensive than the Vortech ... might be playing Russian Roulette with the internals. This would probably be closer to $6K installed.
3) Edelbrock - The most expensive option, but has a lot of advantages. First it is the cleanest looking install of any supercharger I have seen. Second, it runs at relatively low boost 5 or 6 psi, which probably would be safer for the internals. The hp numbers are comparable, but don't seem to be pushing my luck. I just think, by the time I bought the kit and had it installed & tuned, I would have $8K in a supercharger.
Thoughts and experiences would be helpful. Looking for low price, quiet idle (would rather hear the exhaust), absolute minimal risk to internals, high longevity.
Thanks in advance.
Dear Professor:
I've been thinking about this too, as I plan to go FI next spring. My deal is a little different in that I race my car a lot, bracket racing. I know something will break eventually. But, I want the next step in power and also want something streetable. I am either going with the DOB or the Paxton 2200. I made a list of the pros and cons of each and included some questions as well. Not trying to highjack this thread, just it's the same topic and I think this is relevant to what you are looking at, thinking about doing. Whichever one I get I will install myself. For me it will come down to if I want to take my car to the all out race level, roll bar, trans swap, forged bottom end, the works, eventually or not. If not, then I am leaning toward the DOB. And that intake is just so damn cool looking!
If I had 3.31s and stock converter, I'd go DOB. But 4.10s and 3K cnverter with the DOB would be a hoot and should push my car to about as fast as I can go without a roll bar, if I can get traction.
Super charger compare and contrast
Car usage: mainly drag raced in the 1/8 mile with drag MT SS drag radials. Do not want to move to the Radial Pro or slicks, as I drive the car to the track, etc. Needs to be fun/easy to drive on the street, too.
GT450 DOB
Pros:
-Price: 5000.00 (4400+300 for tune+200 for wideband, + need a pc, spark plugs?/misc 100.00)
-Tune: data logging, custom
-instant torque; should shine in the 1/8 mile; should be fun with slushbox
-current 3K converter should work well
-I have the suspension to handle the torque
-OEM look, very clean, stock looking
-included fuel pump/wiring upgrade (can up power without needing new.upgraded fuel system??)
-all GT parts so if I have a problem, a dealership could help with it?????
Cons:
-Install looks a little more involved than Paxton
-not as much max power?
-“hidden” costs? (are there any? like needed a better HE)
-heat soak?, still have the heat exchanger to install
-need wideband and portable PC (I currently have neither); (but will have better tune)
Paxton NOVI 2200
PROS:
-Price 5900.00, includes email tune, simple
-install looks straightforward
-car will drive “stock” under 3K
-big power later if wanted
-power ramping up would work good with drag radial tires
-BAP easier to install (but would need gt500 fuel system later for big power)
-plugs included
-would shine in the ¼ mile
-4.10 gears are well suited
-I’ve worked with brenspeed and had a good experience with them
-Includes an email tune. Already have SCT
-don't mind turning it to 6500 (d
Cons
$900.00 more than GT450 kit
-doesn’t look oem
-ramps up power over the curve, not as good for 1/8 mile where you need the power right away; or would want 4k converter (more money)
-to upgrade power might need gt500 fuel system???
-39#injectors (GT450 comes with 47# injectors)
-might need more converter
