So, should I bring the two-step to the same setting as the stall or should I go a little below the stall? Or, over the stall? It's a turbo car and I would like to load the motor some to build boost while on the two-step. Thoughts?
Thanks, I was just curious if it's common to launch above, below or at your stall. I don't have the availability of a transbrake and need to footbrake the car. So, depending on track conditions I might not be able to hold it to certain RPM's.
I wouldn't set the 2 step higher than your stall, seems like it would be useless up there.
