- Joined
- Dec 17, 2009
- Posts
- 62
- Reaction score
- 1
BMR Suspension Adjustable Front and Rear Sway Bar Kit for S550 Mustang
Improve handling, reduce body roll, and increase cornering stability with an adjustable sway bar kit for the S550 Mustang from BMR Suspension. Designed from 35mm (front) and 25mm (rear) DOM steel tubing, the BMR sway bars are cold formed to better resist torsional fatigue and retain "memory" far longer than conventional hot-formed bars. The BMR Adjustable Sway Bar Kit (PN SB043) gives you 28%-70% (front) and 63%-208% (rear) increase in sway bar rate over the stock bars, reducing body roll and improving handling. BMR Suspension designed these adjustable sway bars for street performance, autocross, and road race applications. The SB043 feature three positions on the front sway bar and three positions on the rear sway bar. They attach to the car with 88-durometer polyurethane bushings, greatly reducing the deflection seen in rubber bushings. Thrust washers locate the sway bars, eliminating lateral movement under aggressive cornering. Front sway bar (SB044) and rear sway bar (SB045) are also sold separately. Installation time is 2-3 hours. Available in black hammertone or red powdercoat. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
