Hello all,
2007 Mustang GT
After current work, no more clunkin, accelerates better, but is a little floaty/bouncy. I want the car to be less bouncy and feel planted. Handle curves better.
All recently installed new:
gt500 A arms w/ bjs and bushings
stock height struts
Rear stock height shocks
Front sway bar end links
Poly front sway bar bushings
Inner/outter tie rods
Do I need to get an alignment if I install a watts link?
Do I need an aftermarket sway bar to accompany the watts link?
Would weld in subframe connectors improve handling?
Any recommendations?
Thank you!!!
2007 Mustang GT
stock height struts
Thank you!!!
