hunterwiley
As another data point, I'll post my experience as a racer in American Iron. My 05 car runs 14" stoptech brakes. The replacement rings are $500 a pair, not cheap but there are many more expensive. On my old fox AI car, I initially ran the stock rotors with the smaller Brembo calipers, and found the NAPA gold rotors to be about the best of the "stock" rotors. I eventually swapped to the 13" stoptech kit with the 2pc rotors, and found my rotors would last an entire season instead of 2 weekends on the stockers. I've always run cooling ducts, with 3" blowers in the ducts. I got 'em hot too, with a race weight of 3200lbs... DTC60's up front, DTC70s in the rear.
I just swapped new pads onto my 05 car after running last weekend at VIR. The pads that came off didn't need to be swapped out just yet, but I've got a day of training with a pro driver next weekend and don't want to be screwing around with the car any more than necessary, so I swapped new one on. The rotors on the car have quite a bit of heat checking but no cracks. I expect they'll last a few more events, but have a spare set just in case. I run Hawk DTC70 pads up front, 60's in the rear on stock rotors. I've never had a set crumble off the backing plate, so I think managing the heat is the key to getting them (any) to last. I've never tried carbotechs, but might in the future... My 05 car races at 3400lbs btw...
This is the fluid I use... Available from Speedway motors for $18 for 17oz, rate for 600+ degrees.
