Bravado Tribute Wheels
djzombie40
I am thinking of buying Bravado Tribute wheels for my 2014 Track Pack. Will they clear the brembo brakes? Specs shown in attached image. Thanks!
Gabe
Whippled Coyote
If you're planning on putting a fat (305+) rear tire on those rear wheels, and you're lowered, you're most likely gonna end up with tire-fender contact back there, over bumps.
An 11"-wide rear wheel on these cars should really be closer to 60mm offset for them to tuck inside the fender over bumps or if on air-suspension.
As far as the front fitment, I believe they'll work just fine.
The factory Shelby '07-'09 wheels are 18x9.5 with a 45mm offset, so they stick in further by 10mm, and they obviously still fit fine
