fastregalwe2
Need more powa!
As useless as this thread might be, I am writing it anyway. Car is 08 Saleen around 500-525RWHP with 555Rs and 4.10s in the rear. Been hearing some clunking for a couple weeks somewhere in the driveling when Id let the clutch out in first gear. Was going to look at it but was too lazy. Drove the car from Va Beach to St. Louis and no issues. Was up there about a week and got 30 miles out of St. Louis headed back and shifted into 5th and clunk. Sounded like the driveshaft was banging the floor pan. I pulled over and jacked it up driveshaft is fine. So I moved it around the parking lot and its def in the rearend. Called 10 tow trucks and no one wanted to tow it either because it was low (Saleen) or because I only needed it to go 5 miles. Anyway, after getting it trailered to a friends house I didn't even bother to pull the rear cover. I just left it there in her driveway and drove back to VA. I'm thinking the center pin with that little 8mm bolt broke or it snapped an axle shaft. Its smoother rolling and then I can feel it clunk and when it does that it kinda wiggles the rear of the car. I cant get back up there for over a month either to even start to fix it. blaaaaaaa!!!
